As I await receipt of the Axoloti I ordered last week and read the posts here, I thought Id say hi and get a reality check on the project I have planned for it...
I live in Michigan USA and play "guitar" through all the effects possible in my band EnD
Anyway, the plan is to put the Axoloti at the end of my signal chain before the loop station and have 2 primary effects...
1. Some type of doppler panner like the one in the parasites firmware upgrade for warps
Possibly controlled by a joystick... also a huge fan of volume sensing and responsive effects
2. best delay ever, with various effects only applied to the trails... Ive wanted to do this for a long time and have attempted it by splitting a wet signal chain off my delay, but never as cool as I wanted...
Hoping for modulation, bit crush, distortion, pitch shift, whatever... feeding back and creating chaos with too many knobs and switches.... Fulliy distinct Left/Right separation with variable feed back bleed between so I can run them against each other...
I was also considering using an arduino for the control surface so I can have a display and be all fancy.
Anyway, I figured you guys might be able to point me in the right direction or tell me Im crazy and save me some time.
Its lonely down here, but someone's got to represent..
