First of all, sorry for the patch looking like a mess, it was made in a hurry. My video capture software also seems to have bad sync problems but you get the idea.
I currently have two questions:
1) I would like the filter envelope depth to not be able to go down to zero even if I turn the *c all the way down. I'd like to know a way to set a range for it like I have done for the resonance and cutoff dials for example. I can not figure out a way to achieve this, anyone got tips?
2) The accent... I got the resonance to add a little attack time on the FEG. I got the decay to be a set time when accent happens. But I would also like a better way to make the accent increase the FEG amount. As it is, the accent uses the set depth, and no accent uses a fraction of that but at low depths it doesn't seem right. I assume I have to build the whole FEG section again, ideally with one envelope?
Thoughts?
edit: I realized the filter has to be 4 pole so I chained two identical filters with shared cutoff and resonance controls, is that the right way to do it?
sounds great!! but why did make a table for the square?
