Hey
I wanted to learn how to work with subpatches, so I started off with making a simple multimode filter with Clean, Lp, Bp and Hp filters. I think it is nice to be able to choose filtertype with out having to change object from Lp to Hp, etc.,. It works kind of like a regular synth.
Connect audio signal to the input and output and choose which filtertype you want. Set cut off and resonance as you like. You control all the filters from the same cut off and resonance dials. Very simple. I am planning to add modulation inputs, another set of three filters and serial/parallel option, but this was just to get familiar with subpatching.
EDIT: I have made an update version wich is a bit more fun The picture is of the subpatch loaded in a normal patch. You can still open and edit it by "edit object definiton" or just take a look under the hood.
Old One:
MMFilter.axs (3.7 KB)
New updated multimode parallel filter with modulation input:
MMFilterParallel.axs (6.3 KB)
Picture of the new one with modulation mixer example:
