Hi Guys,
I would like to implement the below Max snippet somewow in Axoloti, if it is possible.
Is is basically an AM modulator, I use this as my own ac encoder, my own "Silent Way" plug-in, if I can say.
With my active AC encoder module in my modular, I can convert 0-1 floating signals from Max into 0-10 volts.
As you can see, the bas is a 22050 Hz sine oscillator, which is modulated by a floating point number, from other devices, sequencers, etc.
Is it possible to implement this somehow?
