Trying to make a patch with two different synths inside, and I want each respond to notes etc on different midi channel
there is a "Midi IN keyboard Channel", multi-timbral MIDI iN or something similar? how to make this?
Create sub-patches, easiest with the patch/patcher object.
Adjust midi channel in patch settings.
Wow! really love this object ; )
Is there a limit in sub patch levels? I mean... can sub-patches live in other sub-patches or there is a limit?
You can use subpatches inside subpatches. I did that a lot to start with. But sometimes I got errors I couldnt get rid of, so now I use only one "layer" of subpatches. That works really well If you want to use a lot of subpatches I would advice you to set all the settings in the picture to zero. Or else you will easily reach the limit of the SDram in Axoloti:
This have to be set on each subpatch individually.
