Hi guys,
recently I developed a new patch with several controls, I started to mapping them with MIDI CC and it worked great until I mapped the 24th control, after that the patcher refuses to go live is there a limit of controls to be mapped with MIDI CCs? If I have about 50-60 controls how I could go on ?
Thank you for support
K
Midi CC Mapping Limit?
KF78
jaffasplaffa
Thet patch refuses to go live - Can you post the log from the Axoloti window?
There should be some info in that log that might show what the issue is.
cire
Looks like you've reached the sRAM limit.
maybe your patch is too big. Try reorganize your objects so that cables always go from left to right, and top to bottom. This can save quite some ram, especially red and blue ones.
CC assign take ressources, so that might help you have more.
cire
also if you don't use preset or modulation sources, you can put everything to zero in view/settings. I think that reduces ressources too.
