i agree, it is a bit surprising that this has not been hit more. However, it seems that what's in this section in practice is a pointer to a list of function pointers, which thus corresponds to at most two instructions.
Another way of looking at it is that if the problem had caused more problems, it would have been fixed earlier as it would have been more obvious that something waas wrong. By sheer luck, the instructions resulting from the pointers have in most cases been harmless, if that hadn't been the case, the system would have crashed and misbehaved so often that someone would have needed to have a lok at it a long time ago.
To me, it's quite obvious that the constructor/destructor arrays should not be called as code ... and it wasn't always that way, those sections were introduced in commit
203580f5... on 2015-08-04, thus it wasn't part of the original design. The constructor list is explicitly traversed in xpatch_init2(), so there's no way it can be meant to be executed directly.
It all ties in with the symptoms too: the dependence on the patch size, especially that it is not a linear correspondance, i.e. patches don't necessarily break over a certain size, the relative independence of the firmware code, the fact that the constructor code in my case equates to setting r4 to 1 which is the behavior I've observed, not to mention the disassembly of the code actually executed when calling PATCHMAINLOC.
Anyhow, I tested my 'problem patch' with the constructor and destructor sections moved to after the text section in xpatch.bin, and it works fine now, in all configurations of it (I have been testing by remove one, two or three calls to my printpar() local function, with the the constructors list at the start of xpatch.bin, removing all three has always worked, and depending on the rest of the code removing one or two has sometimes worked, wheras leaving all three there has never worked.)
