Hey there all! I'm very new to Axoloti and I need some guidance.
I have a very specific project that I want to get finished this year, namely:
- A portable sampler with a lofi mic, recording to a SD-card
- The sampler also has a sequencer, reading and playing the samples.
Simple enough I thought, but not simple in hardware as far as I can tell. My initial thought was to use the Axoloti as both the sequencer (with some fx and whatnot) and sampler. When I came to the realisation that Axoloti, powerful as it is, might now have the support needed for the recording side I turned to Arduino and inspiration from Bastl Instruments Microgranny (which is Arudino based with an Adafruit Wave shield).
So in short, I want not only to read samples from the SD-card (sample player). I want both to record and play samples (sampler). Is it still doable doing just with the Axoloti? Mind you I don't need 44.1kHz, I'm perfectly fine with low bit rate and 22.05 or lower sample rates and pretty short recordings < 2 sec (since the sample sequencer mainly will work as a drum instrument anyways).
I found a few topics related to this question, but haven't found an answer to this specific problem and I do want to avoid pitfalls in the beginning.
As you might tell I am a beginner in all things hardware, but I'm embarking a new career in embedded systems so I've got time and dedication to learn more.
I'm thankful for any help!
The playback is not really an issue as you both stated. Good to know that the only extra bit of hardware seems to be on the sensor side (simple mic). I have started a design sketch, will probably upload it here later.
