hi
i would like to loop raw files using the play fn object. how would i best do this?
i've tried using the lfo/square object to trigger the files and this kind of works. but the problem is how to set the lfo-frequency to the actual length of the sample?
is there an easier way to do the looping?
(the samples i'll be using could be long. so i'm not sure if i can load them into a table)
many thanks for the help.
bests
c
