Looking to buy an Axoloti Core, but have a few questions first (Mainly about FM synthesis)
Forgive me if all of these questions have been asked/answered independently of each other in different threads, but I couldn't find the specific answers, so I'm asking here!
I'm fascinated by this wonderful tool and would really like to get one myself. Before getting one, I want to make sure that it will do the things I want it to do (in reality, the core can already do far more than most other products that are at a higher price point).
So I would want the Axoloti to be the digital supplemental to the analog synth that I have. In having that, I would like it to perform some exclusively digital functions. They are thus:
  • Musical FM Synthesis: Looking for something that does musically pitched FM synthesis (a la the DX7, or the Volca FM) with operators and carriers, and all that good stuff.
  • Sound Design FM Synthesis: Also looking for something less musical and more "dubsteppy", with gritty dynamic sounds
  • Switching between patches: This is more of a hardware question I guess... Since the musical FM and the sound design FM are in sort of different worlds, I would like to be able to switch between multiple patches with a knob or button, if possible.
Bonus, but not necessary whatsoever: Granular synthesis
Thanks for your time! (I'll probably end up getting one either way!)
fm (or rather pm) is no problem on the axoloti. both "musical" and "gritty" (this depends a lot on harmonic relation between operators) i had great success with a gritty dubsteppy sound by using triangle wave oscillators as operators. aliasing can be an issue then, but in gritty land that may even be desired. happy patching!!
Thank you for your reply! Can you tell me if you can switch patches with it? If I understand correctly, each patch is like its own file that you load into the axoloti, so could you essentially switch between 2 or more patches/files?
switching patches is also possible, yes. there will be a small gap (around 200ms i guess) between the two on loading.
granular stuff is also possible
