Logic/change init to 0?
This might be a matter of preference, I don't know, but...
logic/change seems to initialize to 0, regardless what is connected to it.
This means that it will trigger immediately when going live if a non-zero value is connected to it.
Maybe it would be better to initialize logic/change to whatever is connected to it before going live?
see example patch
logic_init_triggers_on_live.axp (2.3 KB)
Id agree this is not 'consistent' behaviour,
but ... funny Id say it should always trigger on first value... otherwise I think we will get reports that things like sequencers are not playing the first step at startup.
(from a theoretical standpoint id say changes initial state is indeterminate, and therefore a first value is always a change)
this would also be an easy/optimal fix, as we change the init value to say MAX_INT, which would work for all values (except MAX_INT, which is pretty unlikely :)).
I think initialising from an upstream value could be tricky.
