Mark,
I have been trying to get the KS patch into a sub patch over and over in different ways….. but it won't compile.  Both .axp and axs in the same folder.   Thought the asp couldn't find the axs. not sure.
I remember that you guys said some where that an asp doesn't make an axs easily. Tried to copy the contents of the KS patch to a new patch an save as an axs.  Still no polyKS.axp compiled.
Yes I added my folder to the search path with the patch & sub patch.   Can only see the /object folder tho' when I choose new object from the menu.  Added a subpatch directory under objects put the patch & supatch in there still didn't  work.    Is there an object that I'm supposed to choose for sub patching?
./ in the new object requestor aways gets me a demux object, it does not point to were a saved the sub patch.
What am I missing?
PS-I noticed in the youtube build a synth YT saves an AXP as his sub patch?
Thanks in advance everyone.
