I've double checked my installation and everything seems to be set up correctly, but even if I start a patch with just one module it throws an error and won't go live.
Generate code complete
MODULE_PATHS=
compiling C:\Users\mafgar\DOCUME~1\AXOLOT~1.0/build/xpatch.cpp
linking C:\Users\mafgar\DOCUME~1\AXOLOT~1.0/build/xpatch.dbg.elf
C:\Users\mafgar\DOCUME~1\AXOLOT~1.0/build/xpatch.elf :
section size addr
.text 224 0
.rodata 548 0
.init_array 0 0
.fini_array 0 0
.comment 128 0
.ARM.attributes 57 0
Total 957
Done compiling patch
java.io.IOException: Not connected
at axoloti.connection.USBBulkConnection_v2.transmitPacket1(USBBulkConnection_v2.java:415)
at axoloti.connection.USBBulkConnection_v2.sendAndGetReplyPtr(USBBulkConnection_v2.java:677)
at axoloti.connection.USBBulkConnection_v2.mem_alloc(USBBulkConnection_v2.java:797)
at axoloti.connection.USBBulkConnection_v2.transmitStartLive(USBBulkConnection_v2.java:694)
at axoloti.live.patch.PatchViewLive.lambda$goLive$9(PatchViewLive.java:314)
at axoloti.job.JobProcessor.lambda$exec$0(JobProcessor.java:21)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
