Hi there,
I hope some hardware specialists are still around here.
I am planning to use some of the GPIO analog ins as low frequency / band width <<1,5kHz audio ins. The frequency limitation is no problem.
Of course, I would put some second order LP-filters in front of the GPIO in order to avoid aliasing. I suppose 3kHz is the respective sampling rate.
Thus, I have a few questions.
- Does this seen feasible at all? I plan to use 6 additional low frequency (but audio) ins.
- What is the input impedance in analog-in mode? I suppose roughly 100k, according to this thread. https://sebiik.github.io/community.axoloti.com.backup/t/what-is-the-adc-input-impedance-for-connecting-sensors/1773/4. Correct?
- Are the GPIOs biased to a certain voltage level, e.g. VDDA/2? Could this be done by software, or just simply do the biasing by two resistors?
- I plan to protect the GPIO ins by simply using antiparallel NIR IR LEDs with 850nm wavelength. They have a suitable forward voltage of around roughly 1,45V, connected against a capacitor buffered VDDA/2 voltage. Feasible solution?
(Of course I could also use a 1/4 MPC6004 OPA per input, but I like the idea ...)
Thanks in advance!
