Is there a way to have the counter object initialise to 0 ?
had a peek in the code and "count" does get set to = 0 in the init code, however in my patch i have 2 counter objects and both initialise to 1 on startup of the patch, any ideas ?
Initialise logic/counter object to 0
Try using the loadbang object connected to the reset inputs of the counters? Worth a shot.
Sounds like the object is "detecting" a false pulse some how.
yeah as @adnauseam said a const/i set to one patched into the reset inlet should do it.
thank you guys! especially @adnauseam that sorted it right out, didnt know it existed either until now
Adding the const/i is a dirty hack you can find in help files, but it works only if you nail the execution order.
Also, the counter object actually initializes to 0 at startup, however if you use a square lfo to drive the counter, after the first k-rate cycle of the program (pretty quickly, then) the output of the square lfo goes to 1, and the counter advances by 1.
that is exactly what im doing haha, spot on! using the square lfo to drive 2 cycling banks of LED'S, will investigate the const/i tomorrow see if that makes things better
Another way would be to modify the square lfo so that it maintains its initial output (0) for one lfo cycle before the output changes, rather than just one k-rate cycle. Alternatively, modify the lfo so that its initial state is 1 rather than 0, and add an inverter to the output so that the input to the counter really is 0 for one cycle.
Or in practice, create a copy of the lfo object with a modified output, as there are likely other situations where you would want the original behavior. Or add more outputs to the lfo with the different characteristics.
