Hello,
I need a gate like the max/msp one.
https://docs.cycling74.com/max5/refpages/max-ref/gate.html
I've tried the demux object but the behaviour is different.
If I use the demux with 2 outlets, the output is continuous: if I select the first outlet it sends the signal to the first outlet while it send the default value to the second outlet.
Otherwise, if I send the signal to the second outlet, it continues to send the default signal to the first outlet and the incoming signal to the second outlet.
Is there a way to get a gate that sends to the outlet its incoming value only if it is open?
Thanks a lot!
