How to wire potentiometers into MIDI cable with a breadboard?
I've bought a bunch of potentiometers and the like plus a breadboard and MIDI adapter for my project, and I want to connect all of them to a single MIDI cable to go to the Axoloti core. How would I go about doing that? Or is it best to wire them directly into the axoloti core?
What are you trying to acheive? To use the Pot's as controllers?
Are you saying, you want to connect the potentiometers to send MIDI data down a MIDI cable into the Axoloti ? If this is the case, you need to connect the pots to a device that translates the details into MIDI messages.
You can certainly connect them directly to the Axo pins, you can get some connection details from here,
Thanks! This was just what I needed
