If you've got a big patch (and a small laptop) where not all the objects fit on the screen, how do you create a cable that links between two objects that don't fit on the screen at the same time?
How do you connect two objects that are off screen?
jaffasplaffa
You could move the objects closer to each other, connect the cable and then move it to the right position, with the cable connected?
lokki
is there a delay added when i use send and receive objects instead of cable (downwards, left to right)? or is it the same? does the placement of send and receive objects matter?
