I need to use a knob from Axo Control to determine the amplitude of the LFO signal going into a VCO. Normally in my modular I just use a VCA for that, but in the Axo Patcher there is only an audio VCO available... Help please
How do I patch a VCA for data? the only one I see is for Audio only
All an axoloti VCA is is a special multiply object with one audio input and one control input (interpolated up to audio rate). If they're both control rate then you just want one of the multiply (*) objects. Similarly, you can use the audio rate * object for ring modulation.
Lastly, it is always possible to connect a control rate signal to an audio rate input through a conversion object.
