Could I ask for some help please?
I'm using a Novation Circuit as a MIDI source. It sends MIDI note output on Channel 1 and 2.
I am receiving these into Axoloti and want to send Ch1 to one external synth and Ch2 to another with the intention of processing the MIDI in Axoloti before being send on.
I've created two sub-patches with different MIDI Channel settings but Channel 2 does not appear to be sending and i'm unsure why.
Could anyone help me out here?
EDIT: I should add I know the two channels are sending from Circuit as notes are passed through correctly using TB's midithru module.
devThru.axp (7.4 KB)
) , check midi selector then hit update on sub-patch, you now select the midi channel on the subpatch object.
