Error after updading to 1.0.9
I have just updated to the latest Release and now I have this error, which I absolutely don't know what to do with :confused:
all my prevously saved patches don't work now. Can someone tell me what to do?
Object lifecycle
That error also occurs here after a library sync. To get rid of it, delete the file:
C:\Users\Documents\axoloti\axoloti-contrib\objects\tb\env\cycle ad.axo
I'm sure that object will be fixed in no time flat, once tb spots this thread :slight_smile:
fixed, and sync libs should resolve...
(though i fear a conflict if you have started modifying the file system, if you do get this you will need to reinit)
this is caused by a change in code in 1.0.10, which means its fine in 1.0.10, not in 1.09
.... pertinent to the discussions we are having in developer/object lifecycle..
tanks :slight_smile: works now :))
