Erro compiling/ making live patch
Generate code complete
MODULE_PATHS=C:\Users\geert\Documents\axoloti-2.0.0\axoloti-factory\modules\brds
processing module C:\Users\geert\Documents\axoloti-2.0.0\axoloti-factory\modules\brds
make[1]: Entering directory 'C:/Users/geert/Documents/axoloti-2.0.0/build/brds'
linking brds.dbg.elf
c:/program files (x86)/gnu tools arm embedded/7 2018-q2-update/bin/../lib/gcc/arm-none-eabi/7.3.1/../../../../arm-none-eabi/bin/ld.exe: cannot open linker script file axoloti_api_version.ld: No such file or directory
collect2.exe: error: ld returned 1 exit status
make[1]: Leaving directory 'C:/Users/geert/Documents/axoloti-2.0.0/build/brds'
make[1]: *** [C:\PROGRA~2\Axoloti\app\env/module-rules.mk:20: brds.dbg.elf] Error 1
make: *** [C:\Users\geert\Documents\axoloti-2.0.0\axoloti-factory\modules\brds/include.mk:15: C:\Users\geert\Documents\axoloti-2.0.0/build/brds/brds.elf] Error 2
Done compiling patch
I get this error with almost every brds component i try to use
Please help :slight_smile:
The 'brds' modules don't work in Axoloti 2.0
Downgrade to the latest version of Axoloti 1 and it will work (along with some other modules!)
Thx for the quick answer..
Downgrading via de axoloti app does not work for me, nothing happens
I think you misunderstood.
It is suggested that you completely remove Axoloti 2.0. And then, install Axoloti 1.0.12.
You will also need to downgrade the Axoloti firmware to the version that works with 1.0.12.
Ah ok I understand now.. but why are these not working brds modules available in version 2.0.. it's very difficult to know up front what works or not if the ones that don't work are still selectable/available in this version
Unfortunately, there is virtually no communication from the developer.
On GitHub, 2.0.0 says ‘pre-release’ and ‘may contain severe issues‘. The release notes for 2.0.0 also say the MI (mutable instrument) stuff doesn’t work.
On github, Axoloti-1.0.12-2 is marked ‘Latest Release’
It has been almost a year since Johannes put the 2.0.0 pre-release package on GitHub. I see little evidence this project is moving forward in any useful way.
