Hi AxoloFriends!!
I would like to build an hybrid String Machine with raw waveforms generated by the Axoloti and an analog JH Triple Chorus as the Ensemble effect.
My deep wish would be to sound as close as possible to the Eminent 310U and/or the ARP Solina.
These two instruments roughly share the same Phase Locked Divide Down architecture. A single master oscillator generate a high frequency Square Wave that is divided down into octaves. The resulted square waves are then filtered and clipped to get the "puls-ish" waves below. I believe the main difference between these two machines is a matter of low pass filtering on the raw waveforms before the ensemble effect
Achieving these kind of waves from square waves wasn't too difficult but the major difficulty is to emulate the "phase lock" architecture.
Mr Tiar (aka Smashed Transistors) already helped me a lot and provided me a patch made of 12 phasors feeding a phase selector that allows to get phase locked sinus waves. I’m also in contact with the creator of an amazing Reaktor emulation of the Eminent 310U (https://www.native-instruments.com/fr/reaktor-community/reaktor-user-library/entry/show/4923/) who also helped with the filtering.
With all these information, I managed to modify Tiar’s code and built the patch below which sounds exactly how I want!! …. but with a maximum polyphony of 4
(Don't blame me, I didn't find out how to share my library, this is why I also uploaded the 2 .axo objects needed to my patch...)
phasorSelect4.axo (1.9 KB)
string2018-3.axh (32.3 KB)
divide.axo (99.3 KB)
I don’t ask for a full polyphony just like the real thing but a minimum of 8 or even 12 would be great ! Can you guys help me to reach this goal?
PS: I’m more a patch guy than a code guy and I'm pretty new to Axoloti, so please be kind with me
