I need something similar to "Mod" (Modulo) object in Pure data to migrate a patch from PD to Axo...
The most similar object I found on the Axo world is "Divremc" (divide by constant with remainder) so i can use the remainder as a "Modulo" out. (there is no Green color "X/Y" object)
The problem is the maximum constant I can set on it is 128 and need to divide by 10000 .
There is a reason for this? why just 128 in a "green I/O" module?
Any ideas?
It is pretty easy to do.
