Hi everyone...
I'm trying to patch what the title says with no success.
I need to read an incoming integer value, and if it exceeds a constant divide it by two, and repeat until it's below that constant. Sound easy enough, but I can't get my head around it.
Any help appreciated.
Divide by 2 the input until it's below a given value (SOLVED)
Are you trying to do this without writing code? It’s very easy to do in C/C++.
What would you want this for?
yes, I'm trying to patch it, the reason being I don't know how to code... If it's not possible to do with standard objects I'd love some hint on how to write the code... I vaguely remember something like until or while loops from some BASH scripts I did, but it was a loooong ago.
I have the sample length of a loop as an integer and I want sync a small delay by setting is length to the larger number (below the table length) that is an even fraction of the loop
Probably indeed easier to do this in code, but just for kicks...
half till lower.axp (3.5 KB)
Note: this crucially relies on the order of the objects.
That's great. As a C programmer (my job, for many years), this just hadn't occurred to me.
Can the order be protected by making this logic a subpatch?
Cheers
