I need to multiply a "k rate integer" (varying from 0 to 10000) by 0.0002 and then subtract 1.
I will need decimal numbers for the multiplication and the result will be with decimal numbers too (half of them will be negative) All possible results will be from -1 to 1 with decimals.
Is this possible in Axoloti?
Sorry if this is dam question but a didn't found how...
Decimal/negative numbers?
Diego
johannes
You seem to be trying to translate a pd patch 1:1, that is not the right approach. Your question about Shepard tone generation is far more relevant.
Diego
you are right...
I think I will try to translate in other way. Just love the sound the most of all I try.
I did Shepard tones in other ways (even with the modular) but this concrete patch is very flexible and dynamic because anything in relative.
