Hi, using a controller object for patchchange and I thought it would be great to also have preset handling in the controller object, but I can not get it to work, nothing happens, but the same objects work as intended if I put them in the normal patch.
I have a theory about this, I suppose that changing presets in a subpatch, as I suppose the controller object is, doesn't effect the main patch, it just changes them in the controller object.
Is that correct? Is there another way to change presets from a controller object or do I have to put the preset objects in every patch?
