I feel silly asking this question, but here goes: I patched a synth and want to control the main parameters using potentiometers. I got the potentiometers connected and into the patch, but I can't get them to do what the controls on the objects do.
Example: I use an ADSR envelope with modulation inputs. I can connect a potentiometer via gpio/in/analog and use it to modulate, say, attack, but only relative to the position of the (virtual) dial on the object. That is, I cannot access the full -64 to +64 via the gpio, but only change the attack time a little bit relative to whatever the dial is set to in the patcher.
What I want is to have the full range of attack time values for the parameter available from my potentiometer; analogously for various other dials, say filter frequency etc. There is a way to do that, isn't there?
Thanks in advance,
Daniel
