Constant-Pitch Variable Delay FX
anyone know if it's possible to create a delay/echo effect with a variable delay time, that doesn't change the pitch of the output when the delay time is tweaked?
Is this possible with existing modules?
a|x
Use The delay version that is not interp version. Then connect a dial to a nointerp and Then The nointerp to The delay(not interp version)
Thanks jaffasplaffa, I will try that.
a|x
Didnt have my Axoloti earlier when I wrote the answer so couldnt post a picture. It looks like this:
Thanks again jaffasplaffa, I will try that when I get home (at work at the moment).
Cheers,
a|x
