ah, sorry to hear this still didn't work for you. I myself was getting quite frustrated by the noise made by the controls when clicked..
Luckily this only is a mouse-problem, not an overall control problem eg midi
Bad mouse response AND MOUSE FIX
I'm having the same problem ever since I've upgraded my display to bigger than full HD (> 1920*1080).
If I put my display back to full HD, it works as normal.
Windows 10, on different machines, different GPU's and all.
All up to date.
ah, that might be helpful too, I got to notice that there's still some weird behavior every now and then..
I'm seeing the same thing as @mtyas, the jitter occurs only at resolutions higher than 1920x1080. Additionally, the higher the resolution, the greater the effect of the jitter.
Note: This is after updating JRE to the latest (version 161) and copying the JRE to the Axoloti folder as described by @SirSickSik above.
Just to add my voice to the confirmations that this problem only occurs at resolutions greater than 1920x1080.
did a test with windows, everything over 1600 horizontal resolution , the issue appears to start.
however, on mac higher resolutions (2880 horz) are perfectly ok.
so appears to be a java/windows specific issue, rather than an Axoloti code issue.
(note: this is a 'developer' note, I'm not saying its not something Axoloti doesn't need to deal with )
a quick test on the current development branch (experimental) seems to show both swing and piccolo views still have the same issue.
( i didn't compile the full image, so didn't have the rescaling - but the native resolutions still exhibits same issue with dials)
Same issue here.
Touchscreen laptop, Win 10, latest Java, wired mouse, resolution 2560x1440.
Knobs don't oscillate between extreme values but quite randomly (with a hint of also trying to follow the correct values).
Tried the OP's solution with no luck.
