Axoloti TEST release 1.0.8
#115
check your credentials etc.
how can you have uncommitted objects if you deleted the folder as I requested?
note: after the init, its possible you might have to exit axoloti and do a sync... (I cant remember this bit about how the bug existed)
but dont do a sync if there are un-commited objects, since thats not right... unless they are your own, and even then you should do this AFTER you have done a successful sync.
@johannes we really need to get 1.0.9 out, its getting frustrating, doing workarounds for 1.0.8 when I know these were fixed months ago in dev :frowning:
#116
I did exactly that procedure, however after the init the contrib folder is not empty but contains a .git hidden folder.
And there are a lot of uncommitted objects
Status: factory (1.0.8,anon) : OK  ( 1.0.8,clean )
Status : home : OK
Status: community (master,sputnki) : OK  ( master,dirty )
Changes for: community (master,sputnki)
removed: objects/phi/switch/sw 2-1f.axo
removed: objects/phi/math/-+ i..axo
removed: objects/phi/switch/sw 1i.axo
removed: objects/toneburst/pattern/nmpgen2.axh
removed: objects/tb/midi/ctrl/push.axo
removed: objects/phi/math/-+c..axo
removed: objects/Jaffa/Sel/sel i 32 +--64D.axo
removed: patches/cpwitz/synths/axo-trautonium.axp
removed: objects/toneburst/osc/sinesync.axo
removed: objects/euxo/in/gate.axo
removed: objects/toneburst/pattern/nmpgen.axo
removed: objects/Jaffa/Sel/sel fb 32D.axo
removed: objects/phi/switch/sw 1b.axo
removed: objects/Jaffa/Sel/sel i 16 +:-64.axo
removed: objects/rbrt/looper/looper_OD_mono.axo
removed: objects/Jaffa/Sel/sel fb 16D.axo
removed: patches/cpwitz/generative/probtrigger.axs
removed: patches/mtyas/autogen/strange-thing.axp
removed: objects/phi/switch/sw 1-2f.axo
removed: objects/tb/midi/ctrl/push/axo_push_led.c
removed: objects/phi/switch/sw 2-1a.axo
removed: objects/tb/script/oneliner_ik.axo
removed: objects/phi/switch/sw 1-2i.axo
removed: objects/Jaffa/Mix/StMix2.axs
removed: objects/tb/midi/ctrl/push/axo_push_browse.c
removed: objects/tb/disp/print f.axo
removed: patches/cpwitz/generative/generatusrex.axp
removed: patches/cpwitz/synths/subharmonic-osc.axs
removed: objects/Jaffa/Mix/StMix4Ch.axs
removed: objects/phi/switch/sw 1-2b.axo
removed: objects/Jaffa/Sel/sel i 64.axo
removed: objects/phi/switch/sw 1f.axo
removed: objects/Jaffa/Filt/MMFilterP.axs
removed: objects/euxo/in/button-led.axo
removed: patches/keyp/Noodling/noise noodle2.axp
removed: objects/tb/midi/ctrl/push/axo_push.c
removed: objects/toneburst/pattern/nmpgen2.axo
removed: objects/tb/midi/ctrl/push/axo_push.h
removed: objects/tb/midi/ctrl/push/axo_push_params.c
removed: objects/tb/midi/ctrl/push/axo_push_funcs.h
removed: objects/Jaffa/Sel/sel fp 16D.axo
removed: objects/Jaffa/Sel/sel i 32 +:-36.axo
removed: objects/Jaffa/Mix/StMix2M.axs
removed: objects/Jaffa/Sel/sel fp 32D.axo
removed: objects/toneburst/pattern/nmpgen3.axh
removed: objects/wp/filter/4polelpf.axs
removed: patches/cpwitz/generative/randomnote.axs
removed: objects/tb/midi/ctrl/push/axo_push_play.c
removed: objects/Jaffa/Sel/sel b 16 pulseD.axo
removed: objects/Jaffa/Filt/MMFilter.axs
removed: objects/Jaffa/Mix/StMix4ChMOut.axs
removed: objects/wp/env/ad_mod.axo
removed: objects/phi/switch/sw 2-1i.axo
removed: objects/tb/disp/print i.axo
removed: patches/cpwitz/generative/automobeep.axp
removed: README.md
removed: objects/rbrt/control/timer.axo
removed: patches/jt/grainy-table.axp
removed: objects/phi/switch/switch.txt
removed: objects/Jaffa/Mix/StMix4.axs
removed: objects/mtyas/reverb/shortverb.axs
removed: objects/phi/switch/sw 1a.axo
removed: objects/rbrt/looper/looper_FB_stereo.axo
removed: .gitignore
removed: objects/Jaffa/Mix/StMix3.axs
removed: objects/tb/midi/ctrl/push/axo_push_handler.c
removed: patches/cpwitz/synths/formant-synth.axp
removed: objects/rbrt/control/clocker.axo
removed: objects/phi/switch/sw 2-1b.axo
removed: objects/toneburst/pattern/nmpgen.axh
removed: objects/Jaffa/Sel/sel b 16 2t pulseD.axo
removed: objects/Jaffa/Mix/StMix3M.axs
removed: objects/Jaffa/Mix/StMix1.axs
removed: objects/wp/ctrl/i radio 5 h.axo
removed: objects/Jaffa/Sel/sel i 64 +:-64.axo
removed: objects/Jaffa/Mix/StMix4M.axs
removed: patches/tb/demo/fbank.axp
removed: objects/tb/midi/ctrl/push/axo_push_scale.c
removed: objects/Jaffa/Sel/sel b 16 4t pulseD.axo
removed: patches/cpwitz/generative/fancyreverb.axs
removed: objects/tb/midi/ctrl/push/axo_push_scale.h
removed: objects/tb/midi/ctrl/push/axo_push_session.c
removed: objects/rbrt/control/gate_hold.axo
removed: objects/tb/audio/mixer.axo
removed: objects/Jaffa/Mix/StMix4ChM.axs
removed: objects/rbrt/looper/looper_FB_mono.axo
removed: objects/mtyas/delay/long-delay.axs
removed: objects/phi/switch/sw 1-2a.axo
removed: objects/tb/disp/print.axh
removed: objects/wp/osc/khaosmachine.axs
removed: patches/cpwitz/synths/half-wave-synth.axp
removed: patches/rbrt/looper_mono_DEMO.axp
removed: objects/tb/midi/ctrl/push/axo_push_pads.c
removed: objects/Jaffa/Sel/sel i 16 +--64D.axo
removed: objects/wp/edrum/snare_mod.axs
removed: objects/phi/switch/switches.axh
removed: objects/tb/audio/audiomix.axh
removed: objects/toneburst/pattern/nmpgen3.axo
uncommited: objects/phi/switch/sw 2-1f.axo
uncommited: objects/phi/math/-+ i..axo
uncommited: objects/phi/switch/sw 1i.axo
uncommited: objects/toneburst/pattern/nmpgen2.axh
uncommited: objects/tb/midi/ctrl/push.axo
uncommited: objects/phi/math/-+c..axo
uncommited: objects/Jaffa/Sel/sel i 32 +--64D.axo
uncommited: patches/cpwitz/synths/axo-trautonium.axp
uncommited: objects/toneburst/osc/sinesync.axo
uncommited: objects/euxo/in/gate.axo
uncommited: objects/toneburst/pattern/nmpgen.axo
uncommited: objects/Jaffa/Sel/sel fb 32D.axo
uncommited: objects/phi/switch/sw 1b.axo
uncommited: objects/Jaffa/Sel/sel i 16 +:-64.axo
uncommited: objects/rbrt/looper/looper_OD_mono.axo
uncommited: objects/Jaffa/Sel/sel fb 16D.axo
uncommited: patches/cpwitz/generative/probtrigger.axs
uncommited: patches/mtyas/autogen/strange-thing.axp
uncommited: objects/phi/switch/sw 1-2f.axo
uncommited: objects/tb/midi/ctrl/push/axo_push_led.c
uncommited: objects/phi/switch/sw 2-1a.axo
uncommited: objects/tb/script/oneliner_ik.axo
uncommited: objects/phi/switch/sw 1-2i.axo
uncommited: objects/Jaffa/Mix/StMix2.axs
uncommited: objects/tb/midi/ctrl/push/axo_push_browse.c
uncommited: objects/tb/disp/print f.axo
uncommited: patches/cpwitz/generative/generatusrex.axp
uncommited: patches/cpwitz/synths/subharmonic-osc.axs
uncommited: objects/Jaffa/Mix/StMix4Ch.axs
uncommited: objects/phi/switch/sw 1-2b.axo
uncommited: objects/Jaffa/Sel/sel i 64.axo
uncommited: objects/phi/switch/sw 1f.axo
uncommited: objects/Jaffa/Filt/MMFilterP.axs
uncommited: objects/euxo/in/button-led.axo
uncommited: patches/keyp/Noodling/noise noodle2.axp
uncommited: objects/tb/midi/ctrl/push/axo_push.c
uncommited: objects/toneburst/pattern/nmpgen2.axo
uncommited: objects/tb/midi/ctrl/push/axo_push.h
uncommited: objects/tb/midi/ctrl/push/axo_push_params.c
uncommited: objects/tb/midi/ctrl/push/axo_push_funcs.h
uncommited: objects/Jaffa/Sel/sel fp 16D.axo
uncommited: objects/Jaffa/Sel/sel i 32 +:-36.axo
uncommited: objects/Jaffa/Mix/StMix2M.axs
uncommited: objects/Jaffa/Sel/sel fp 32D.axo
uncommited: objects/toneburst/pattern/nmpgen3.axh
uncommited: objects/wp/filter/4polelpf.axs
uncommited: patches/cpwitz/generative/randomnote.axs
uncommited: objects/tb/midi/ctrl/push/axo_push_play.c
uncommited: objects/Jaffa/Sel/sel b 16 pulseD.axo
uncommited: objects/Jaffa/Filt/MMFilter.axs
uncommited: objects/Jaffa/Mix/StMix4ChMOut.axs
uncommited: objects/wp/env/ad_mod.axo
uncommited: objects/phi/switch/sw 2-1i.axo
uncommited: objects/tb/disp/print i.axo
uncommited: patches/cpwitz/generative/automobeep.axp
uncommited: README.md
uncommited: objects/rbrt/control/timer.axo
uncommited: patches/jt/grainy-table.axp
uncommited: objects/phi/switch/switch.txt
uncommited: objects/Jaffa/Mix/StMix4.axs
uncommited: objects/mtyas/reverb/shortverb.axs
uncommited: objects/phi/switch/sw 1a.axo
uncommited: objects/rbrt/looper/looper_FB_stereo.axo
uncommited: .gitignore
uncommited: objects/Jaffa/Mix/StMix3.axs
uncommited: objects/tb/midi/ctrl/push/axo_push_handler.c
uncommited: patches/cpwitz/synths/formant-synth.axp
uncommited: objects/rbrt/control/clocker.axo
uncommited: objects/phi/switch/sw 2-1b.axo
uncommited: objects/toneburst/pattern/nmpgen.axh
uncommited: objects/Jaffa/Sel/sel b 16 2t pulseD.axo
uncommited: objects/Jaffa/Mix/StMix3M.axs
uncommited: objects/Jaffa/Mix/StMix1.axs
uncommited: objects/wp/ctrl/i radio 5 h.axo
uncommited: objects/Jaffa/Sel/sel i 64 +:-64.axo
uncommited: objects/Jaffa/Mix/StMix4M.axs
uncommited: patches/tb/demo/fbank.axp
uncommited: objects/tb/midi/ctrl/push/axo_push_scale.c
uncommited: objects/Jaffa/Sel/sel b 16 4t pulseD.axo
uncommited: patches/cpwitz/generative/fancyreverb.axs
uncommited: objects/tb/midi/ctrl/push/axo_push_scale.h
uncommited: objects/tb/midi/ctrl/push/axo_push_session.c
uncommited: objects/rbrt/control/gate_hold.axo
uncommited: objects/tb/audio/mixer.axo
uncommited: objects/Jaffa/Mix/StMix4ChM.axs
uncommited: objects/rbrt/looper/looper_FB_mono.axo
uncommited: objects/mtyas/delay/long-delay.axs
uncommited: objects/phi/switch/sw 1-2a.axo
uncommited: objects/tb/disp/print.axh
uncommited: objects/wp/osc/khaosmachine.axs
uncommited: patches/cpwitz/synths/half-wave-synth.axp
uncommited: patches/rbrt/looper_mono_DEMO.axp
uncommited: objects/tb/midi/ctrl/push/axo_push_pads.c
uncommited: objects/Jaffa/Sel/sel i 16 +--64D.axo
uncommited: objects/wp/edrum/snare_mod.axs
uncommited: objects/phi/switch/switches.axh
uncommited: objects/tb/audio/audiomix.axh
uncommited: objects/toneburst/pattern/nmpgen3.axo
#118
ok, so this is assuming you have deleted everything...
which is odd, that means the initial clone failed, did you get any errors in the console when you did the init().
can you please try it again, I cant think why it would pull the head revision, yet not download the files.
can you give me a screenshot of how you have configured axoloti-contrib.
also double check you have entered your authentication details correctly and also your contributor prefix.
#119
1) i delete the folder
2) i open axoloti, shows medium size error, as planned. No axoloti contrib folder
3) pref -> contrib -> init -> ok -> the contrib folder is back on.
4) i close axoloti. inside the contrib folder there's the .git hidden folder.
5) i open axoloti again, the log is the same i've posted before:
Link to firmware CRC A50E988A
Status : home : OK
removed: README.md
removed: .gitignore
No available USB device found with matching PID/VID
search path : \Users\Filippo\Documents\axoloti\axoloti-factory\objects
search path : \Users\Filippo\Documents\axoloti\objects
search path : \Users\Filippo\Documents\axoloti\axoloti-contrib\objects
finished loading objects
Folder is still empty, except for the hidden .git folder
Credentials are correct, i verified it.
#120
ok, something strange is happening... Ive just tried on windows and I'm getting the same now.
its weird as its not happening on Mac, and it was working on window before.... and doesn't appear to work at all now. (even without authentication)
I'll need to test it some more... or perhaps @johannes as I cant rebuild the windows app.
#121
ok, Ive fixed it.
@Sputnki , do the init again.
The issue was cause by @jaffasplaffa including files with names containing ":" which are not valid under windows.
@jaffasplaffa can you please not use 'special' characters in the filename of objects.
@Sputnki , Im a little 'unhappy' , I asked you if there were any errors in the console in the init, and there were errors about the above file. once I saw this, it took me 2 minutes to fix... instead, Ive ended up having to install 1.0.8 on my windows system, and have had a whole number of posts going through this issue. a waste of both mine and your time.
please guys, read the reporting issues post I made, https://sebiik.github.io/community.axoloti.com.backup/t/reporting-issues-bugs/21
I think its pretty obvious, that any error in the console should be included when you have issues.
it means less leg work for me, and faster solutions for you.
#122
Yep Will look into it when i get back home in a few days. Sorry. I never use Windows for anything and didnt know it was an issue.
#123
no problem, in 1.0.9 you don't get to name files, it automatically names them from the object name, and so accounts for things like this :smile:
#124
I think there may be a bug related to the Glide object in 1.0.8.
Does the following patch loop like it should work, from the attached screenshot?
I managed to get it to work once, but there seems to be a problem with the smoothing amount- a value of 0 seems still to produce a pitch glide (where I assume it shouldn't).
After that one time, it appears to compile and upload (log below), but produces no audio, and there's no activity on the two scopes, either.
I've tried connecting a cntrl/button object to the 'en' input of the Glide object, too, with the same result- no output. With nothing connected to 'en', it works, but no glide, obviously.
Generate code complete
Start creating directory on sdcard : /nmpgen3
creating dir: /nmpgen3
Done creating directory
Changing working directory on sdcard : /nmpgen3
Change working directory: /nmpgen3
Axoloti says: file error: FR_NOT_ENABLED, filename:"/nmpgen3"
Done changing working directory
Start compiling patch
Compiling patch... with /Applications/Axoloti.app/Contents/Java/firmware
BDIR = /Users/alx/Documents/axoloti/build
FIRMWARE = .
RM
rm -f /Users/alx/Documents/axoloti/build/xpatch.o /Users/alx/Documents/axoloti/build/xpatch.elf /Users/alx/Documents/axoloti/build/xpatch.bin /Users/alx/Documents/axoloti/build/xpatch.d /Users/alx/Documents/axoloti/build/xpatch.map /Users/alx/Documents/axoloti/build/xpatch.lst
APP
arm-none-eabi-g++ -nostdlib -fno-exceptions -fno-rtti -mcpu=cortex-m4 -O3 -fomit-frame-pointer -falign-functions=16 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -Wunused-parameter -DCORTEX_USE_FPU=TRUE -DTHUMB_PRESENT -mno-thumb-interwork -DTHUMB_NO_INTERWORKING -mthumb -DTHUMB -std=c++11 -DARM_MATH_CM4 -D__FPU_PRESENT -H -I/Applications/Axoloti.app/Contents/Java/CMSIS/Include -I/Applications/Axoloti.app/Contents/Java/chibios/os/ports/common/ARMCMx/CMSIS/include -I/Applications/Axoloti.app/Contents/Java/chibios/os/ports/common/ARMCMx -I/Applications/Axoloti.app/Contents/Java/chibios/os/ports/GCC/ARMCMx -I/Applications/Axoloti.app/Contents/Java/chibios/os/ports/GCC/ARMCMx/STM32F4xx -I/Applications/Axoloti.app/Contents/Java/chibios/os/kernel/include -I/Applications/Axoloti.app/Contents/Java/chibios/os/hal/include -I/Applications/Axoloti.app/Contents/Java/chibios/os/hal/platforms/STM32F4xx -I/Applications/Axoloti.app/Contents/Java/chibios/os/hal/platforms/STM32 -I/Applications/Axoloti.app/Contents/Java/chibios/os/hal/platforms/STM32/GPIOv2 -I/Applications/Axoloti.app/Contents/Java/chibios/os/hal/platforms/STM32/I2Cv1 -I/Applications/Axoloti.app/Contents/Java/chibios/os/hal/platforms/STM32/OTGv1 -I/Applications/Axoloti.app/Contents/Java/chibios/os/hal/platforms/STM32/RTCv2 -I/Applications/Axoloti.app/Contents/Java/chibios/os/hal/platforms/STM32/SPIv1 -I/Applications/Axoloti.app/Contents/Java/chibios/os/hal/platforms/STM32/TIMv1 -I/Applications/Axoloti.app/Contents/Java/chibios/os/hal/platforms/STM32/USARTv1 -I/Applications/Axoloti.app/Contents/Java/chibios/boards/ST_STM32F4_DISCOVERY -I/Applications/Axoloti.app/Contents/Java/chibios/ext/fatfs/src -I. -I/Applications/Axoloti.app/Contents/Java/chibios -Winvalid-pch -MD -MP --include /Users/alx/Documents/axoloti/build/xpatch.h -c /Users/alx/Documents/axoloti/build/xpatch.cpp -o /Users/alx/Documents/axoloti/build/xpatch.o
! /Users/alx/Documents/axoloti/build/xpatch.h.gch
LINK
arm-none-eabi-gcc -nostartfiles -Tramlink.ld -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mthumb  -mno-thumb-interwork /Users/alx/Documents/axoloti/build/xpatch.o -Wl,-Map=/Users/alx/Documents/axoloti/build/xpatch.map,--cref,--just-symbols=./build/axoloti.elf -o /Users/alx/Documents/axoloti/build/xpatch.elf
BIN
arm-none-eabi-objcopy -O binary /Users/alx/Documents/axoloti/build/xpatch.elf /Users/alx/Documents/axoloti/build/xpatch.bin
Done compiling patch
Start uploading patch
bin path: /Users/alx/Documents/axoloti/build/xpatch.bin
block uploaded @ 0x20011000 length 7564
Done uploading patch
Start starting patch
Done starting patch
Start locking
Done locking
Disconnect request
Here's the patch in question:
nmpgen3.axp (5.6 KB) (requires my nmpgen3 object, which is in the contrib library).
#125
UPDATE:
I've tried with the math/smooth object in place of the Glide.
In this case, I get the same behaviour I saw before- with smooth at 0, I still get smoothing.
If I try to add a multiplexer to switch between the smoothed and unsmoothed pitch (see screenshot), again it fails to make a sound.
I'm just trying to achieve a switched glide effect, based on a boolean output from the nmpgen3 object. I'd have thought this should be possible. Is it something to do with execution order, perhaps, and not a bug after all?
#126
Seems to work if I swap the 'osc/pwm' oscillator for an 'osc/square cheap'. Dunno why...
Could be a bug with the pwm oscillator, then...
nmpgen3 Cheap Sqr.axp (5.6 KB)
#127
I'm sorry, i really did not notice the error after the init, and i thought you were referring to the axoloti patcher startup. I apologize for wasting your time, next time i'll be more careful.
#128
no problem @Sputnki .. I recognise its hard on both sides.
just every now and then, Id like to remind everyone, I also prefer making music with axoloti (and my other gear), Im just another community member helping here, its not my job, I'm not paid etc (like it would be for a Native Instrument support guy) , so I kind of appreciate it when others help reduce the amount I have to do to chase these things down.... I view its as a team effort, where end-users are a vital part of that team.
but as I said, I do recognise its not always easy for those reporting issues to know what is important and not... even on my side sometimes I miss the more obvious causes initially :wink:
@toneburst, id guest this is not 1.0.8 specific i.e. probably same in 1.0.6, so I suspect not high priority on 1.0.8 for fixing. (1.0.8 does mean we can update objects between software releases, so not vital its fixed before 1.0.9 is out) - not saying not important, just may not get priority at the moment.
#129
I see. Were you able to confirm it's a bug, just out of interest?
I'm a newb when it comes to using the Patcher, but I think my patch should work, conceptually, at least. The fact it Does work, with a different oscillator object suggests Bug pretty strongly to me.
#130
By looking a little bit more into it, axoloti changed The names of The objects. Actually i didnt use The : sign, i used the / sign. But axoloti changed The : to /. But Will avoid using Those special characters at all. Just letters & numbers?
#131
I'd avoid both.
The forward-slash '/' character is the path delimiter on UNIX-based systems (including OS X). It can't be used in OS X filenames, but I guess the system replaces them with ':' characters, behind the schenes, while displaying the original forward slash you typed in Finder (but not in other apps like the Axoloti patcher).
#132
the substituting rule for : / is SLASH, as axoloti substitutes with words, e.g. * becomes STAR.
anyway, I just pushed a change for 1.0.9 that means : becomes COLON.
but yeah best avoid special characters, as there are quite a few that could cause issues.
in 1.0.9 when you use 'add to library' it shows you the filename that is going to be used, so if its still has odd characters, best not to use it ... and if its a useful one, let us know and we can ensure its gets substituted.
#133
Well, me an Axoloti object editor have never been friends. Never worked for me. I make som changes and changes are gone when I close the editor.....I am probably doing something wrong..... So I am still doing custom objects in Text Wrangler and name them there cause that worked everytime. But if it works in new version i will definatly give it a go :smile:
#134
I noticed a little error into the subpatch object dist/hardclip.axs: it does not work, since the +c_2 object inside should be s-rate when instead is k-rate.
#135
@thetechnobear
So, today I had time to change the names of the objects in Finder in OSX. Do I have to change the name of the objects in textwrangler also(the name that is shown in the editor)? Or is it enough to just change the name in Finder?
I dont have any Windows machine so cant really test if they would work on Windows now.
What do you say? :smile:
