This is my version of the build.sh file - actually only 3 changes - add LinuxMint & commented out some files
!/bin/bash
set -e
echo -e "\n\nAxoloti Install script for Linux"
echo -e "This will install Axoloti"
echo -e "Use at your own risk\n"
echo -e "Some packages will be installed with apt-get,"
echo -e "and all users will be granted permission to access some USB devices"
echo -e "For this you'll require sudo rights and need to enter your password...\n"
echo -e "Press RETURN to continue\nCTRL-C if you are unsure!\n"
read
PLATFORM_ROOT="$(cd $(dirname $0); pwd -P)"
ARCH=$(uname -m | sed 's/x86_//;s/i[3-6]86/32/')
if [ -f /etc/lsb-release ]; then
. /etc/lsb-release
OS=$DISTRIB_ID
elif [ -f /etc/debian_version ]; then
OS=Debian # XXX or Ubuntu??
elif [ -f /etc/arch-release ]; then
OS=Archlinux
else
OS=$(uname -s)
fi
case $OS in
Ubuntu|Debian|LinuxMint) # add linux Mint and comment out libraries below
echo "apt-get install -y libtool libudev-dev automake autoconf ant curl" # lib32z1 lib32ncurses5 lib32bz2-1.0"
sudo apt-get install -y libtool libudev-dev automake autoconf \
ant curl # lib32z1 lib32ncurses5 lib32bz2-1.0
Archlinux|Arch)
echo "pacman -Syy"
sudo pacman -Syy
echo "pacman -S --noconfirm apache-ant libtool automake autoconf curl lib32-ncurses lib32-bzip2"
sudo pacman -S --noconfirm apache-ant libtool automake autoconf curl \
echo "Cannot handle dist: $OS"
exit
esac
cd "$PLATFORM_ROOT"
./add_udev_rules.sh
mkdir -p "${PLATFORM_ROOT}/bin"
mkdir -p "${PLATFORM_ROOT}/lib"
mkdir -p "${PLATFORM_ROOT}/src"
if [ ! -d "${PLATFORM_ROOT}/../chibios" ];
then
cd "${PLATFORM_ROOT}/src"
CH_VERSION=2.6.9
ARDIR=ChibiOS_${CH_VERSION}
ARCHIVE=${ARDIR}.zip
if [ ! -f ${ARCHIVE} ];
then
echo "##### downloading ${ARCHIVE} #####"
curl -L http://sourceforge.net/projects/chibios/files/ChibiOS_RT%20stable/Version%20${CH_VERSION}/${ARCHIVE} > ${ARCHIVE}
else
echo "##### ${ARCHIVE} already downloaded #####"
fi
unzip -q -o ${ARCHIVE}
mv ${ARDIR} chibios
cd chibios/ext
unzip -q -o ./fatfs-0.9-patched.zip
cd ../../
mv chibios ../..
else
echo "##### chibios directory already present, skipping... #####"
fi
if [ ! -f "$PLATFORM_ROOT/bin/arm-none-eabi-gcc" ];
then
ARCHIVE=gcc-arm-none-eabi-4_9-2015q2-20150609-linux.tar.bz2
then
echo "downloading ${ARCHIVE}"
curl -L https://launchpad.net/gcc-arm-embedded/4.9/4.9-2015-q2-update/+download/$ARCHIVE > $ARCHIVE
else
echo "${ARCHIVE} already downloaded"
fi
tar xfj ${ARCHIVE}
cp -rv gcc-arm-none-eabi-4_9-2015q2/* ..
rm -r gcc-arm-none-eabi-4_9-2015q2
else
echo "bin/arm-none-eabi-gcc already present, skipping..."
fi
if [ ! -f "$PLATFORM_ROOT/lib/libusb-1.0.a" ];
then
ARDIR=libusb-1.0.19
ARCHIVE=${ARDIR}.tar.bz2
then
curl -L http://sourceforge.net/projects/libusb/files/libusb-1.0/$ARDIR/$ARCHIVE/download > $ARCHIVE
else
fi
tar xfj ${ARCHIVE}
cd "${PLATFORM_ROOT}/src/libusb-1.0.19"
patch -N -p1 < ../libusb.stdfu.patch
./configure --prefix="${PLATFORM_ROOT}"
make
make install
else
echo "##### libusb already present, skipping... #####"
fi
if [ ! -f "${PLATFORM_ROOT}/bin/dfu-util" ];
then
ARDIR=dfu-util-0.8
ARCHIVE=${ARDIR}.tar.gz
if [ ! -f $ARCHIVE ];
then
curl -L http://dfu-util.sourceforge.net/releases/$ARCHIVE > $ARCHIVE
else
fi
tar xfz ${ARCHIVE}
cd "${PLATFORM_ROOT}/src/${ARDIR}"
./configure --prefix="${PLATFORM_ROOT}" USB_LIBS="${PLATFORM_ROOT}/lib/libusb-1.0.a -ludev -pthread" USB_CFLAGS="-I${PLATFORM_ROOT}/include/libusb-1.0/"
make
make install
make clean
ldd "${PLATFORM_ROOT}/bin/dfu-util"
else
echo "##### dfu-util already present, skipping... #####"
fi
case $OS in
Ubuntu|Debian|LinuxMint) # linux mint added
echo "apt-get install openjdk-7-jdk"
sudo apt-get install openjdk-7-jdk
Archlinux)
echo "pacman -Syy jdk7-openjdk"
sudo pacman -S --noconfirm jdk7-openjdk
esac
echo "##### compiling firmware... #####"
cd "${PLATFORM_ROOT}"
./compile_firmware.sh
echo "##### building GUI... #####"
cd "${PLATFORM_ROOT}"/..
ant
echo "DONE"
