Is patch bank upload or controller object functionality broken somehow?
I'm trying to upload patch bank with controller object in 1.0.12
When I restart Axoloti Board nothing happens.
Axoloti says:
file error: FR_NO_FILE, filename:"/START.BIN"
While uploading patch bank Axoloti says:
Uploading patch bank file Compiling and uploading : 8ap-loop-plus2MIDI.axp Using controller object: controller/buttsnpngnchng Unable to created controller for : controller/buttsnpngnchng Generate code complete sdcard filename:/8ap-loop-plus2MIDI/patch.bin Compiling and uploading : LushFDNMIDI.axp Using controller object: controller/buttsnpngnchng Unable to created controller for : controller/buttsnpngnchng Generate code complete sdcard filename:/LushFDNMIDI/patch.bin Compiling and uploading : 4layergranulator-extMIDI.axp Using controller object: controller/buttsnpngnchng Unable to created controller for : controller/buttsnpngnchng Generate code complete sdcard filename:/4layergranulator-extMIDI/patch.bin Compiling and uploading : GrainverbMIDI.axp Using controller object: controller/buttsnpngnchng Unable to created controller for : controller/buttsnpngnchng Generate code complete sdcard filename:/GrainverbMIDI/patch.bin Compiling and uploading : BodeBBD-MIDI.axp Using controller object: controller/buttsnpngnchng Unable to created controller for : controller/buttsnpngnchng Generate code complete sdcard filename:/BodeBBD-MIDI/patch.bin Compiling and uploading : GrainFreezeMIDI.axp Using controller object: controller/buttsnpngnchng Unable to created controller for : controller/buttsnpngnchng Generate code complete sdcard filename:/GrainFreezeMIDI/patch.bin Patch bank uploaded Start uploading file to sdcard : /index.axb uploading: /index.axb uploading : 100% Done uploading file Start compiling patch BDIR = C:\Users\palkin\DOCUME~1\axoloti/build FIRMWARE = . RM APP ! C:\Users\palkin\DOCUME~1\axoloti/build/xpatch.h.gch LINK BIN Done compiling patch Creating directory on sdcard : /8ap-loop-plus2MIDI Done creating directory Start uploading file to sdcard : /8ap-loop-plus2MIDI/patch.bin uploading: /8ap-loop-plus2MIDI/patch.bin uploading : 100% Done uploading file Start compiling patch BDIR = C:\Users\palkin\DOCUME~1\axoloti/build FIRMWARE = . RM APP ! C:\Users\palkin\DOCUME~1\axoloti/build/xpatch.h.gch C:\Users\palkin\DOCUME~1\axoloti/build/xpatch.cpp: In member function 'void rootc::instancefdn_dash_container::instanceap1::instanceallpass__1::dsp(const int32_t*, int32_t (&)[16], int)': C:\Users\palkin\DOCUME~1\axoloti/build/xpatch.cpp:2880:23: warning: integer overflow in expression [-Woverflow] int32_t g2c = ((1<<31)-1)-g2; ^ C:\Users\palkin\DOCUME~1\axoloti/build/xpatch.cpp: In member function 'void rootc::instancefdn_dash_container::instanceap1::instanceallpass__3::dsp(const int32_t*, int32_t (&)[16], int)': C:\Users\palkin\DOCUME~1\axoloti/build/xpatch.cpp:2917:23: warning: integer overflow in expression [-Woverflow] int32_t g2c = ((1<<31)-1)-g2; ^ C:\Users\palkin\DOCUME~1\axoloti/build/xpatch.cpp: In member function 'void rootc::instancefdn_dash_container::instanceap1::instanceallpass__4::dsp(const int32_t*, int32_t (&)[16], int)': C:\Users\palkin\DOCUME~1\axoloti/build/xpatch.cpp:2954:23: warning: integer overflow in expression [-Woverflow] int32_t g2c = ((1<<31)-1)-g2; ^ C:\Users\palkin\DOCUME~1\axoloti/build/xpatch.cpp: In member function 'void rootc::instancefdn_dash_container::instanceap1::instanceallpass__2::dsp(const int32_t*, int32_t (&)[16], int)': C:\Users\palkin\DOCUME~1\axoloti/build/xpatch.cpp:2991:23: warning: integer overflow in expression [-Woverflow] int32_t g2c = ((1<<31)-1)-g2; ^ C:\Users\palkin\DOCUME~1\axoloti/build/xpatch.cpp: In member function 'void rootc::instancefdn_dash_container::instanceap2::instanceallpass__1::dsp(const int32_t*, int32_t (&)[16], int)': C:\Users\palkin\DOCUME~1\axoloti/build/xpatch.cpp:3898:23: warning: integer overflow in expression [-Woverflow] int32_t g2c = ((1<<31)-1)-g2; ^ C:\Users\palkin\DOCUME~1\axoloti/build/xpatch.cpp: In member function 'void rootc::instancefdn_dash_container::instanceap2::instanceallpass__3::dsp(const int32_t*, int32_t (&)[16], int)': C:\Users\palkin\DOCUME~1\axoloti/build/xpatch.cpp:3935:23: warning: integer overflow in expression [-Woverflow] int32_t g2c = ((1<<31)-1)-g2; ^ C:\Users\palkin\DOCUME~1\axoloti/build/xpatch.cpp: In member function 'void rootc::instancefdn_dash_container::instanceap2::instanceallpass__4::dsp(const int32_t*, int32_t (&)[16], int)': C:\Users\palkin\DOCUME~1\axoloti/build/xpatch.cpp:3972:23: warning: integer overflow in expression [-Woverflow] int32_t g2c = ((1<<31)-1)-g2; ^ C:\Users\palkin\DOCUME~1\axoloti/build/xpatch.cpp: In member function 'void rootc::instancefdn_dash_container::instanceap2::instanceallpass__2::dsp(const int32_t*, int32_t (&)[16], int)': C:\Users\palkin\DOCUME~1\axoloti/build/xpatch.cpp:4009:23: warning: integer overflow in expression [-Woverflow] int32_t g2c = ((1<<31)-1)-g2; ^ C:\Users\palkin\DOCUME~1\axoloti/build/xpatch.cpp: In member function 'void rootc::instancefdn_dash_container::instanceap3::instanceallpass__1::dsp(const int32_t*, int32_t (&)[16], int)': C:\Users\palkin\DOCUME~1\axoloti/build/xpatch.cpp:4916:23: warning: integer overflow in expression [-Woverflow] int32_t g2c = ((1<<31)-1)-g2; ^ C:\Users\palkin\DOCUME~1\axoloti/build/xpatch.cpp: In member function 'void rootc::instancefdn_dash_container::instanceap3::instanceallpass__3::dsp(const int32_t*, int32_t (&)[16], int)': C:\Users\palkin\DOCUME~1\axoloti/build/xpatch.cpp:4953:23: warning: integer overflow in expression [-Woverflow] int32_t g2c = ((1<<31)-1)-g2; ^ C:\Users\palkin\DOCUME~1\axoloti/build/xpatch.cpp: In member function 'void rootc::instancefdn_dash_container::instanceap3::instanceallpass__4::dsp(const int32_t*, int32_t (&)[16], int)': C:\Users\palkin\DOCUME~1\axoloti/build/xpatch.cpp:4990:23: warning: integer overflow in expression [-Woverflow] int32_t g2c = ((1<<31)-1)-g2; ^ C:\Users\palkin\DOCUME~1\axoloti/build/xpatch.cpp: In member function 'void rootc::instancefdn_dash_container::instanceap3::instanceallpass__2::dsp(const int32_t*, int32_t (&)[16], int)': C:\Users\palkin\DOCUME~1\axoloti/build/xpatch.cpp:5027:23: warning: integer overflow in expression [-Woverflow] int32_t g2c = ((1<<31)-1)-g2; ^ C:\Users\palkin\DOCUME~1\axoloti/build/xpatch.cpp: In member function 'void rootc::instancefdn_dash_container::instanceap4::instanceallpass__1::dsp(const int32_t*, int32_t (&)[16], int)': C:\Users\palkin\DOCUME~1\axoloti/build/xpatch.cpp:5934:23: warning: integer overflow in expression [-Woverflow] int32_t g2c = ((1<<31)-1)-g2; ^ C:\Users\palkin\DOCUME~1\axoloti/build/xpatch.cpp: In member function 'void rootc::instancefdn_dash_container::instanceap4::instanceallpass__3::dsp(const int32_t*, int32_t (&)[16], int)': C:\Users\palkin\DOCUME~1\axoloti/build/xpatch.cpp:5971:23: warning: integer overflow in expression [-Woverflow] int32_t g2c = ((1<<31)-1)-g2; ^ C:\Users\palkin\DOCUME~1\axoloti/build/xpatch.cpp: In member function 'void rootc::instancefdn_dash_container::instanceap4::instanceallpass__4::dsp(const int32_t*, int32_t (&)[16], int)': C:\Users\palkin\DOCUME~1\axoloti/build/xpatch.cpp:6008:23: warning: integer overflow in expression [-Woverflow] int32_t g2c = ((1<<31)-1)-g2; ^ C:\Users\palkin\DOCUME~1\axoloti/build/xpatch.cpp: In member function 'void rootc::instancefdn_dash_container::instanceap4::instanceallpass__2::dsp(const int32_t*, int32_t (&)[16], int)': C:\Users\palkin\DOCUME~1\axoloti/build/xpatch.cpp:6045:23: warning: integer overflow in expression [-Woverflow] int32_t g2c = ((1<<31)-1)-g2; ^ LINK BIN Done compiling patch Creating directory on sdcard : /LushFDNMIDI Done creating directory Start uploading file to sdcard : /LushFDNMIDI/patch.bin uploading: /LushFDNMIDI/patch.bin uploading : 77% uploading : 100% Done uploading file Start compiling patch BDIR = C:\Users\palkin\DOCUME~1\axoloti/build FIRMWARE = . RM APP ! C:\Users\palkin\DOCUME~1\axoloti/build/xpatch.h.gch LINK BIN Done compiling patch Creating directory on sdcard : /4layergranulator-extMIDI Done creating directory Start uploading file to sdcard : /4layergranulator-extMIDI/patch.bin uploading: /4layergranulator-extMIDI/patch.bin uploading : 100% Done uploading file Start compiling patch BDIR = C:\Users\palkin\DOCUME~1\axoloti/build FIRMWARE = . RM APP ! C:\Users\palkin\DOCUME~1\axoloti/build/xpatch.h.gch C:\Users\palkin\DOCUME~1\axoloti/build/xpatch.cpp: In member function 'void rootc::instancepatcher__1::instanceallpass__1::dsp(const int32_t*, int32_t (&)[16], int)': C:\Users\palkin\DOCUME~1\axoloti/build/xpatch.cpp:647:23: warning: integer overflow in expression [-Woverflow] int32_t g2c = ((1<<31)-1)-g2; ^ C:\Users\palkin\DOCUME~1\axoloti/build/xpatch.cpp: In member function 'void rootc::instancepatcher__1::instanceallpass__2::dsp(const int32_t*, int32_t (&)[16], int)': C:\Users\palkin\DOCUME~1\axoloti/build/xpatch.cpp:684:23: warning: integer overflow in expression [-Woverflow] int32_t g2c = ((1<<31)-1)-g2; ^ C:\Users\palkin\DOCUME~1\axoloti/build/xpatch.cpp: In member function 'void rootc::instancepatcher__1::instanceallpass__3::dsp(const int32_t*, int32_t (&)[16], int)': C:\Users\palkin\DOCUME~1\axoloti/build/xpatch.cpp:721:23: warning: integer overflow in expression [-Woverflow] int32_t g2c = ((1<<31)-1)-g2; ^ LINK BIN Done compiling patch Creating directory on sdcard : /GrainverbMIDI Done creating directory Start uploading file to sdcard : /GrainverbMIDI/patch.bin uploading: /GrainverbMIDI/patch.bin uploading : 100% Done uploading file Start compiling patch BDIR = C:\Users\palkin\DOCUME~1\axoloti/build FIRMWARE = . RM APP ! C:\Users\palkin\DOCUME~1\axoloti/build/xpatch.h.gch LINK BIN Done compiling patch Creating directory on sdcard : /BodeBBD-MIDI Done creating directory Start uploading file to sdcard : /BodeBBD-MIDI/patch.bin uploading: /BodeBBD-MIDI/patch.bin uploading : 100% Done uploading file Start compiling patch BDIR = C:\Users\palkin\DOCUME~1\axoloti/build FIRMWARE = . RM APP ! C:\Users\palkin\DOCUME~1\axoloti/build/xpatch.h.gch LINK BIN Done compiling patch Creating directory on sdcard : /GrainFreezeMIDI Done creating directory Start uploading file to sdcard : /GrainFreezeMIDI/patch.bin uploading: /GrainFreezeMIDI/patch.bin uploading : 100% Done uploading file Start uploading file to sdcard : /index.axb uploading: /index.axb uploading : 100% Done uploading file
Controller object worked fine in 1.0.11
