I recently purchased a used Axoloti Core off of reverb.com. It arrived today and when I went to power it on for the first time (using the same USB cable that I use for my other board) all I get is a really dim LED 1 (red). Here are a few other things I noticed if it's helpful:
- There is a faint pop from the audio output when I connect power.
- The board is not recognized as a USB device when attached to a computer.
- Manually pushing switch 1 causes the dim LED 1 to turn off while the switch is pressed.
Is this behavior that anyone else has experienced? Are there any troubleshooting steps I should try before I tell the seller that they sold me a dud (or it was possibly damaged during shipping)?
Thanks in advance!
