Axocontrol Amusement
I've been on this forum over a year, and never shared a patch... until now.
A friend recently built a Soma Labs Lyra-8, which uses two LFOs to create a ‘hyper LFO’.
This patch started off as an experiment to watch how two LFOs can interact when running at different rates. (Button A switches between ANDing them and ORing them)
The patch uses the Music Thing Modular Axocontrol - I've modified the axocontrol object to
efficiently debounce (filter, smooth) the pot inputs. The patch could be easily modified for a different control setup.
My first shared patch - I hope somebody finds it amusing.
soma_hyper_lfo_4a.axp (12.4 KB)
Thank you for the patch and the first share :slight_smile:
I looked at it last night, but didn't have the board around. Hopefully I will tonight.
I don't have an Axo control, but will sort it out in some way :slight_smile:
How does the debouncing code work or look like? I don't have an axocontrol but I had serious problems with this with another raspberry pi project of mine. The bounce filtering had to be set so high that it introduced too much lag with my implementation.
You can just download the patch and check the code out?
I could not find it in the patch. @tele_player said he modified the axocontrol object, probably outside of the patch
Look again. I converted a773/axocontrol into an embedded object, and modified it. The filtering is an exponential weighted moving average. The code I uploaded uses a factor of 100:
#define A_NUM 100
But that’s definitely much higher than necessary, 10 works well.
