After alittl bit of testing, it seems like if I have made preset 4 and STAY on preset 4, go unlive and live again, preset 4 will be lost. Nothing happens when pushing the update display button..
BUT.... If I go to preset 1 BEFORE going unlive and live again... ALL presets will be there when going live again. This happens even if I disconnects the sequencer from the save object and only connect a button to it.
Can you make anything of that?
Beside that... This is SUPER cool... Really.... This makes track progression a bliss in Axoloti and opens up for serious complex sequences with just a mouse click.. Hell, yuo could even just connect a logic counter and use that to change presets automatically as the track progresses for full automated track.....
Was also just wondering if more than 16 presets is wanted, 32 for example, I could just double the table size, right? instead 32X4 = 128 samples table?
EDIT: the issue mentioned above with presets being deleted only happens sometimes. I tried taking the presets selector OUT of the sequencer object and instead of the radio buttons I used a ctrl/i....
But anyway, once the sequences are saved correctly and you go unlive and live again they work and recall correctly. I guess one solution is just having a patch for writting sequences in and the just use them in patches you need it in.
