Hi all, Is there an object that allows you to type in hz/note values instead of fractionals/ints? I'm also looking for an object that displays the tempo/bpm of an object to 3 decimal places? I found sputnki's 24ppq to bpm object, unfortunately it's displaying the bpm as an integer.
Are there any objects/patches that allow you to type in a Hz/Note value?
jaffasplaffa
I dont think it is perfect match for what you need, but check dr.justices object called: drj/ctrl/dial_pitch
Reggie
@grimmreefer unfortunately that's only displaying the hz/note value, what I'd like to be able to do for example is type in 50hz or E4 into the dial control and have the dial automatically set itself to the closest fractional value that matches, notes should be relatively simple as they appear to be integer values on the fractional dial.
jaffasplaffa
Yeah, I understand. The object cannot be set like that as is now. As far as I know. Toneburst thinks the same. Maybe later on
