heh, methinks enthusiastic entrepreneurs have done just that and are now desperate to recoup their losses
Finally completed my enclosure project! Based on the design by javantomme! I learned a lot by doing this, among others, that things get easier, if you leave some space in the enclosure.
Hi !
This week my Axoloti core has arrived...
( Very fast and happy, Thank you Johannes)
As I have a LASER cutter, So decided to make several models of wooden enclosures..
Here are some photos ...
Wooden enclosure for AXOLOTI CORE SYNTH and Raspberry Pi 3 B+ boards.
The design of this case is made to not have to use many screws.
As an example
A pre-cut has been made in the lid in order to add Rotary Encoder.
The case are made of laminated 3mm Birch wood.
Screw and nuts 10mm long and 3mm in diameter
and of 2,5mm for the fixation of the boards.
External dimensions L 167mm x W167mm x H 43mm
I have placed an advertisement on eBay for which you are interested.
https://goo.gl/EE2Kjo
@killor those look nice ...
I notice on your way ad, you are based in Granda, Im just up the road from you - just past Guadix
(is that a picture of the alhambra in the background of the first pic?)
I wonder if later I need something 'custom' , could you quote for me? nothing too complex, and Id prepare the plans etc.
(it will be a while yet, as ive other things on-the-go at the moment)
Hi Thetechnoear
Yes, I live in Granada city... Right. in front of me I have the Alhambra .
No problem, for doing something customized ..
I just need a vector file, type DXF, SVG or CORELDraw ..
when you have the sketch send me a message
to realize..
Regards...
I also got 2 cases from Believotron and am very happy with them. I modified one to include an OLED display based on @SmashedTransistors 's instructions and object. Eventually I'm going to get a proper CNC'ed metal case so I can use the axoloti in my pedalboad. I'm going to expand the 2 stereo audio IO plugs to 4 mono TS jacks and add a little input buffer to one audio input so i can connect my guitar directly. Here is my hacked Believotron case:
Hi !
This week I made another enclosure model
Something intermediate in terms of size.
Exterior measurements, approximate in millimeters: L 167 x W 84 x H 42
It is made in 2 versions.
All in wood and another All in clear acrylic.(The blue of the photo is the protective film
I hope you like it.
https://i.ebayimg.com/images/g/OhIAAOSw6XNa0Ji0/s-l1600.jpg
I'm sorry but I do not know what is a Bastl 60 ?
But if you give me a sketch with the measurements in mm, it can be done ..
Not an enclosure perse, but a 3d printable mounting kit:
This should make it easier to do a neat/secure mounting in whatever box you have in mind.
You can find the files on thingiverse:
axoloti mount kit
@killor
hi, i dont have bit coins. could you cut me one in wood with some modifications like holes for pots and so...? i am in south portugal.
Hi Moutcast
Yes, I can make it...
I just need you to send me a sketch
with the measurements of the POT ... and how many holes and their approximate location ..
in a PDF template...
On the subject of the BTC, do not worry, I also accept payments by PayPAL ..
I send to all the world and of course to our good neighbors Portuguese !!
Here's a compact companion to the Roli Block, handmade from a block of plywood.
As I tried to keep the dimensions at absolute minimum with inputs maxed out, it was a bit tricky fitting everything in but a bit of carving here and there helped. One led is for LFO, the other one is just pilot light.
Planning to still add the extensions of buttons s1 & s2 for changing patches but having hard time finding a suitable place..
Does anyone have a pointer to a reasonably priced laser-cutting supplier in EU for the jvantomme case?
I hunted for someone who could do the 2mm/3mm setup required, but am struggling to find anyone suitable; i.e. who can work with both 2mm/3mm materials, or can do so for a reasonable shipping cost. Alas a lot of manufacturers I found only do 3mm as a minimum.
A couple of posts above... you can ask @killor ?
https://sebiik.github.io/community.axoloti.com.backup/t/anyone-planning-to-make-and-sell-an-enclosure/140/334?u=keyman
