I observed this issue on Ubuntu 14.04, Axoloti Patcher 1.0.10-15-geb6308, developer build date: 19/05/2016 22:15:34 EDT.
In Preferences, Library, first search path entry is default, Name "factory", Location: "https://github.com/axoloti/axoloti-factory.git" Library is enabled.
I went to hook up my 16th analog input today and couldn't find PC5, ADC1_IN15.  After inspecting the source for gpio/in/analog, the reason is clear, the entry is missing from the XML fields for the MenuEntries and CEntries for the object:
            PC2 (ADC1_IN12)
            PC3 (ADC1_IN13)
            PC4 (ADC1_IN14)
   11
            12
            13
            14
The source code seems to be the same, missing the entry for Analog Input #15, in branches 1.0.6 - 1.0.10 and current master:
I'm hoping there's no preventative reason this input can't be used?!  Anyways, I'm going to try to hand-edit and see if it works  Hurray for user-editable source code!
btw i fooking lurf this program.
