Hi!
I'm taking a note from a midi keyboard, then calculating a note higher than it and a note lower than it. This is fine, but THEN I want to be able to glide between the new high note and the new low note. With each new keypress I want to jump immediatly to the high pitch then glide to the low pitch (with the glide time controlled by another dial elsewhere - but looking at the glide objects I've found, this bit will be the easy bit).
The thing I'm struggling with is how to tell the glide object two notes at same time and that it should interpolate from high to the low, regardless of where it'd got to previously... can anyone help?
