I have a click at start of sample playback after renaming the other sonic boom wav samples to raw, abhoth’s raw samples are fine though, is renaming them ok?
Or should they be converted some other way?
Abhoth Contributions
          Leetut
        #22
          Abhoth
        #23
      The data in a wav file starts with a header with some «metadata» like sample rate, etc. This section is of varying length, but ends with the characters «data». A raw file does not have this header, only the actual audio.
So, if you renamed a wav to raw, what you are hearing is probably the header played as if it were audio.
